Power question (PSU Seasonic M12II EVO 620W)
Jovan93
768
hello i have one question about the power this is the issue:
on Vcore i have: 1.368v
on +3.3V i have: 3.312v
on +12V i have: 12.097
that is fine i quess cause it above the first value but i have problem with +5V why is it at 4.950V can anyone help me with this? can it do any harm to anything?
This are my specs:
AMD FX 8350
ASUS GTX760 DirectCUII OC 2Gb
ASUS M5A99FX PRO R2.0
Kinsgston Furry 2x4Gb 1866MHz
The CPU is manualy clocked by me using this https://www.youtube.com/watch?v=MckeAmnDeTk Video i changed some values of the multiplaier and that stuff to get the same numbers on the RAM which is 1866MHz run the test for 2hrs on prime95 and everything was fine but the lower +5V was from the beggining when i first start up the system before even OC so thats not the problem what is your opinion? is this wrong that much so i must change or do something with the PSU? maybe its faulty?
