Power Requirement for MSI GTX 760
StackOverbuffer
30
I was wondering if my Cooler Master V650S can provide enough power on an MSI GTX 760 TF OC. I wanna make sure it does before I buy the graphics card tomorrow
You only need 30A on the 12V rail and 500W total minimum for a gtx 760.
The coolermaster can supply 54A - http://www.coolermaster.com/powersupply/modular-vs-series/v650s/
Its made by Enhance and is 80plus Gold certified. The V series are better though - made by Seasonic.
If you already have it then use it. Else try something from Seasonic eg their 520W or XFX550 or Antec HCG 520M
The GTX 760 requires a minimum of 30A on the 12v+ Rail and a minimum of 300W.
The CM V650 Provides a total of 54A on the 12v+ Rail and exceeds the minimum of 300W requirment.
Your PSU will more than do the job you can even go ahead and OC your GPU too.
