Question Power Requirement.
Nov 23, 2020
5
I have Rx 560 4 gb
2 hdds and i5 2500
Optiplex 790
Stock PSU rates 250 watts
Can i run this gpu without any issue ?
Joseph_138
115
17
4,585
Core i5-2500 is 95W. RX 560 should be 75W. You're already up to 170 W without counting anything else plugged into the motherboard, drives, or case fans. It might work, but you'll really be pushing up close to the limit of what this PSU can handle. PSU's also degrade over time, so if this system is very old, then it has probably started to deteriorate already and will struggle to deliver the power you need.
