Power requirements for small DIY speakers?
unspeakable
Notable
Oct 13, 2017
252
I have no idea, about anything on powering speakers. Information is below.I want to set it up so that is as loud as possible with good-decent audio quality.
I am planning to use Triple A Batteries for this project. These are 1.5v 1Amp
Amp - Output Power: 0.1W-5W ;4-32 Ohms
Supply voltage: DC 1.8-12V
Input Interface: 3.5mm Audio input
Adjust form: volume adjustment
Speakers-
Type: Passive
Channels: 1
Impedance: 8 ohm
Power: 1.0W
Max Power:1.5W
S.P.Z:100dB
FO:
550±20%Hz
Frequency Range:
FO-8000Hz
Distortion:
10% Max at 1000Hz 1.0W.
Even though I'm an engineer, I don't do calculations for projects like that.
With all due respect to my audiophile friends, 1.5 W speakers are not rocket science.
I Just Wing It!
Be brave. Experiment.
What's the worst that can happen? So you lose a few bucks.
But you will have learned something.
Part Express will have everything you need and cheap.
https://www.parts-express.com/
In November I found a Phillips 5-speaker soundbar in the dumpster.
I took it apart to remove the center speaker to make room for the amp.
Rewired the 4 remaining drivers to be in stereo.
Cut a hole in the back so a $10 Part Express 18W amp could hang out
and used the biggest power supply (14.4V - 3A) the amp could take.
My GF loves her new speakers. They are much clearer and louder than the old ones.
Ok. I contacted the seller and they said it was 1-1.5 Watts at 1V. That means the amperage is from 1-1.5. Now how much power should I be giving the Amp in Volts and Amps for the maximum on these speakers.
I Just Wing It!
