Power saving techniques
Does the following methods extend battery life?
1) Turning off inbuilt speakers
2) Disabling GPU/not installing GPU driver
3) Undervolting CPU
4) Less taskbar apps
5) Disconnecting USB devices like mouse/keyboard when not in use.
Hello... basically a Computer part is made of transistors that turn off and on to control current from your battery.
SO... any method to keep a transistor from switching will reduce current flow.
1) Yes
2) Yes, but modern GPU's have already 3 Power/mhz reducing steps programed into them.
3) Use CPU Speed Step instead, like the above mentioned, Power/mhz reducing steps programed into them.
4) Yes, if there is LED/Laser lighting being used on them.
1) The spearkers use power to play sound, but when idle there is no power used
2) While yes not powering the gpu would help life, but then your computer wont work or display anything
3) You can use power management to limit CPU max power. This will help but is usually always set by default
4)Yes and No. If the app is actively using the cpu then yes, otherwise no
5) Yes, anything the laptop has to power while drain battery.
Turning screen brightness down helps battery life.
Fine tuning power settings for quicker hard drive/cpu turn off and dissabling NIC and other not used devices will help.
Installing an SSD drive helps battery life and performance
Hello... basially a Computer part is made of transistors that turn off and on to control current from your battery.
1) Yes
I do mainly two things on my laptop. Watch movies/videos, browse internet. Will undervolting helps to increase battery life or selecting "power saver" does the job?
#1 nope
#2 nope. There should be power options (either Windows or the GPU's control panel) that will only allow the laptop to use the integrated graphics core.
#3 can improve battery life the most. But laptops generally do not give you an option to undervolt the CPU.
#4 generally yes because the less apps are running in the background then technically the less work the CPU needs to do so that it idles longer.
#5 the difference will not be too much since those devices generally do not draw too much power. But it should add several minutes.
The primary way to prolong battery life is to:
1. Lower screen brightness
2, Switch the power option to Power Saving Mode; which may vary from laptop to laptop if manufacturers include their own profiles. Windows should have a "Balanced" profile if not "Low Power".
3. Put the laptop in "Airplane Mode" which basically disables all wireless communication that includes WiFi and Bluetooth. This should be found in network settings. Of course, if you need to be connected, then do not switch to Airplane Mode.
4. Replace the hard drive (HDD) with a solid state drive (SSD). SSD consumes a lot less power than HDD because of no moving parts. However SSD are relatively expensive. If the laptop already has a SSD, then is point is moot.
Hello... HW Monitor, RealTemp and GPU-Z such APPS can allow you to see the stepping action... My GPU runs at the Low speed with internet streaming... But its a GTX760 B ) but look at GPUZ app running and check it... it also Displays your Power consumption, use the sensors tab. http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
I've disabled the wireless adapter, brightness is at the lower most that it didn't make my eyes to zoom and see. Using power saving mode as much as possible. Can I undervolt by referring this guide?
