Power Source 2x2 pin
Seth_8
Commendable
Feb 18, 2016
7
I have a 2x2 pin (dont know what its called) that powers my back ports including my onboard graphics and i want to put in a new power source for a new graphics card but the new power source doesnt have that
Hmm. Most contemporary systems have a 20 or 24 pin ATX connector + 4 pin/8 pin connector for the CPU VRMs. Not heard of a 4-pin connector for graphics that wasn't an inline 4-pin molex connector.
This isn't an OEM machine from e-machine, dell, compaq, or some other brand? They often use custom wiring and power supplies which makes them difficult to upgrade.
If you provide the exact model I can probably tell you more, but generally these aren't the type of systems that are conducive to upgrades. Some more popular machines do have adapter kits out there you can find on ebay and amazon. Only other option is to buy the appropriate connectors and do some re-wiring.
That's a standard connection for CPU power , any decent power supply should have it or an 8 pin that SPLITS TO MAKE 4+4.
This power supply has six SATA connectors, two Molex/peripheral connectors, an FDD connector, two 6 pin PCIe connectors, a 24-pin ATX connector and a non-standard 20 pin 12V CPU connector. While this isn’t very many connectors for a 750 watter, it’s more than enough for the PC it came from, since it only had six HDD bays, and came with two mid-range graphics cards. Note that in the above picture, the CPU connector has been replaced with a standard 4 pin connector, powered only by the fourth 12V rail, since the original 20 pin connector won’t work with my load tester. All of the cables do come sleeved, but only up to the first connector. There is no sleeving in between the connectors.
http://www.hardwareinsights.com/wp/dell-h750p-00-review/
