power suplly calculation help for gtx 750
xachinj4497
98
My current rig
Intel Pentium g2010 (55w)
Mobo intel dh61ho
Ram 2x2gb 655MHz ddr3
1hdd 1 dvdrw
Mouse keyboard
Gpu- asus nvdia geforce 210 1gb ddr3 (31 watts)
And my power supply intex(watts i dont know)
On label it is written that total output shall not continuously exceed 200w
And it has 18a on +12v rail
My main ques. Is for "REPLACING A GT210 TO GTX 750(55W)"
I think it is addition of 25-30 watts to my system
My current rig with this psu running very smooth & noise less
http://www.flipkart.com/antec-vp450p-450-watts-psu/p/itmda3ncpuga3hpu?pid=PSUDA3NCT4Z4SKKR&otracker=from-search&srno=t_1&query=antec&ref=1182f2e3-24c7-4346-9552-bf4b3e7ab123
Antec VP450P / 450 Watts PSU
The Powersupply is the heart of the computer. All the hardware problems occurs due the use of poor Powersupply like intex, tech-com and zebronics. Personally I have lost a Hard Drive and two modules of RAM because of a bad Powersupply. So what I can tell is change your Powersupply first. The cheap and best Powersupply in the market is Corsair VS450. It would cost you around 2450rs in flipkart. I got one for 2200rs from a local shop.
http://www.flipkart.com/corsair-vs450-450-watt-psu/p/itmdbfa3kaffmum3?pid=PSUDBF9ZBHSJVGJ8&otracker=from-search&srno=t_1&query=vs+450&ref=2177095e-41cd-466c-b5ef-4ddd02dd5ad1
Antec VP450 is comparatively very good but it is little expensive. It will cost you around 2800rs.
http://www.flipkart.com/antec-vp450p-450-watts-psu/p/itmda3ncpuga3hpu?pid=PSUDA3NCT4Z4SKKR&otracker=from-search&srno=t_1&query=antec&ref=cb9efb43-483d-47d9-aa3a-37752d4334de
Get any one of the above two PSUs which will suit your budget.
Totally agree with you. But it is little bit expensive. If you are okay with the price, go for VP450P else there is no other choice apart from VS450 in indian market 🙁
I was just seeing both psu
Due to tight budget i have to choose vs450
I bought defective vs450 has no 4 pin connection for mobo nd with intex there was a 4 pin connector for mobo
It will work only with 24-pin connection?
