Power suply LC-Power LC6650GP3 V2.3
softa
60
LC-Power LC6650GP3 V2.3 is this PSU goodenough for GTX 560 TI overclock edition and an AMD phenom 2x4 960 T unlocked six cores overclocked on 3,4ghz , 8gb ram , 2 Fans on Thermaltake contact 30
Make sure you know which one you're getting. The current revision has 80 PLUS BRONZE certification and a much stronger combined +12V rails (45.8 Amps). I've read a review of this current model and it is able to deliver the 45.8 Amps. The original version has no 80 PLUS certification and has a weak combined +12V rails (30.7 Amps).
Current Revision:
Original:
I love how they advertise that it's a 650 watt power supply, but it can actually only supply 368 watts on it's 12v lines. What I do know though is that my Phenom II X4 965BE with a 7850 pulls a smidgen over 350 watts from the wall and the 560ti uses a pretty good chunk of power more than my 7850, and your CPU is unlocked and overclocked which would use even more than my 965be.
Personally, I wouldn't run it with that supply.
Generally you want to look for a supply that has the rated wattage on it's 12v line somewhere near it's total rated capacity. For instance, When I google Silverstone 500W you get this image: http://images.anandtech.com/doci/4908/17_leistung.jpg
Notice how it's a 500watt supply and the 12v line supplies 34 amps, so 12 * 34 = 408 watts. Not too bad, but not great either.
The original supply you linked has 2 12v rails, 19A each, so 19 * 12 = 228 watts for each rail, but it has a note right on it that the total of the two can't exceed 368 watts... 368 for a 650 watt advertised supply? Terrible.
Something like a Corsair CX 500 found here: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139027 . . . 38 amps for a 500 watt supply, so 12 * 38 = 456 watts... much better.
It doesn't always work out that you get a quality supply that way, but since computers these days get a vast majority of their power from the 12v lines (it didn't used to be that way, which is why some are designed differently) it will really help when shopping around. Do you have to buy it from a specific store or something, is that why you only have a few models to choose from?
As a personal preference I usually like to stick to single rail designs so there are no issues with using adapters in weird scenarios later, but that's more of a preference than a requirement.
The LC600H-12 you mentioned is 480 for a 600 watt supply, while it would probably run your machine just fine take note that the CX500 I mentioned above can supply 456 and is rated at 500 watts and this one only 480 for 600 watts? It sounds like they are trying to over sell what their supply can actually do from the overall capacity rating, which I think is usually a bad sign for the overall quality of the product.
Current Revision:
Original:
its the first picture , what dou you think , is that an good psu , i can get a http://
You would think they would have changed the model number or something, the newer one is a way better design for modern machines.
thank you im buying it today
