Power Supplies & Cooling for i7 5820K
bhalton26
197
Plan on OC this CPU to 4.0 so it will do better with games vs the i7 4790K. I know the majority of the board see 4790K as a better gaming choice for today but I want to be ready for the gaming of tomorrow. I only plan to OC the CPU, won't touch the GPU since I plan to Crossfire instead of SLI.
Is there a real difference between Silver, Gold, & Plat rated PSUs? I'm thinking of theses: EVGA vs CORSAIR 850W or do I need 1000W since I plan to CFX?
850W
EVGA 220-GS-0850-V1 850W ATX12V / EPS12V 80 PLUS GOLD Certified @ $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438034
CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI GOLD @ $149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Cooling
CORSAIR Hydro Series H90 High Performance Water/Liquid CPU Cooler. 140mm @ $89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181036
CORSAIR Hydro Series H105 Extreme Performance 240mm Liquid CPU Cooler @ $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181060
CORSAIR Hydro Series H100i Extreme Performance Water/Liquid CPU Cooler. 240mm @ $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181032
Case
Since I'm using the NZXT Phantom 820 Series Case, I'm thinking the H90 should be enough that way I can use the rear fan as the out take vs having to remove the top fans to install the H105 or H100i. Then again, that's two extra fans I can use to mount else where inside the case.
I have build a 5820k rig for a friend with Scythe Katana 4 as cooling as he said he won't be overclocking for now. With a 25$ Katan 4 the CPU doesn't go over 60 C at stock clock, i was surprised at how cool it run compared to 4790 at stock.
Water cooling is not cost efficent, if you want silent high performance cooling go with
if it fits your case, it offers better cooling at lower noise for cheaper.
If the Noctua doesn't fit your case, this Silverstone HE01 one should -> http://www.silverstonetek.com/product.php?pid=341&area=en
