Power Supplies
gentilco
4
I RECENTLY BUILT MY NEW COMPUTER AND AM TRYING TO FIND OUT WHAT IS THE RIGHT WATT FOR A POWER SOURCH TO GET THIS MACHINE RUNNING?
ANY HELP WOULD BE GREATLY APPRECIATED.......THANKS
HERE ARE ALL MY SPECS:
COMPUTER CASE: (NEW)
NZXT PHAN-003RD Phantom Full-Tower Case - E-ATX, ATX, Micro ATX, 5 x 5.25" Bays, 7 x 3.5"Bays, 200mm LED Fan, White / Red
MOTHERBOARD: (NEW)
BIOSTAR A770E3 AM3 AMD 770 ATX AMD Motherboard
PROCESSOR: (NEW)
AMD Athlon II X2 260 Regor 3.2GHz Socket AM3 65W Dual-Core Desktop Processor ADX260OCGMBOX
PROCESSOR FAN: (NEW)
LOGISYS Computer BETA 200ST AC2200BT 92mm Hydro Bearing AMD CPU Cooler
MEMORY (RAM): (NEW)
G.SKILL Value Series 2 Sticks - 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9S 4GBNT
VIDEO CARD: (OLD)
BFG Tech BFGR79512GTXOCE GeForce 7900GTX 512MB 256-bit GDDR3 PCI Express x16 SLI Support Video Card
HARD DRIVE (MAIN): (OLD)
Western Digital Caviar Green WDBAAY0010HNC-NRSN 1TB 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
HARD DRIVE (SECOND): (OLD)
HARD DRIVE (THIRD): (OLD)
Western Digital Caviar Blue WD3200AAKX 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
DVD DRIVE (MAIN): (NEW)
Lite-On iHBS112-29 12X 3D Internal Blu-Ray Writer - BD-R SL 12X, BD-R DL 8X, BD-RE SL/DL 2X, DVD±R 16X, DVD-RAM 12X,
DVD+RW 8X, DVD-RW 6X, CD-R 48X, CD-RW 24X, 3D Playback, Black (OEM)
DVD DRIVE (SECOND): (OLD)
Sony Optiarc 24X DVD Burner, Bulk Package 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model AD-7280S-0B - OEM
DVD DRIVE (THIRD): (OLD)
SOUND CARD: (OLD)
Creative Sound Blaster Audigy SE 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - OEM
INPUT DEVICES: (OLD)
StarTech Model ESATAPLATE1 12" (1 ft.) eSATA Data Internal to External Slot Plate
gentilco
4
ORIGINALLY I WAS THINKING I NEEDED AROUND 450W SO I PURCHASED:
DiabloTek PHD550 ATX Power Supply - 550W, 140mm Fan, 20+4 Pin
AT MY MACHINE WOULDN'T TURN ON SO I THOUGHT DOA MAYBE I THEN SWAPPED IT OUT FOR A OLD PSU I HAD WHICH WAS:
BFG 600W
STILL WOULDN'T TURN ON SO I WENT A BOUGHT A NEW:
CORSAIR Gaming Series GS700 700W ATX12V v2.3 80 PLUS Certified Active PFC High Performance Power Supply
COMPUTER TURNS ON
I CANT AFFORD THE 115 DOLLARS IT TOOK TO BUY THAT PSU SO I WILL HAVE TO RETURN IT I RECENTLY PURCHASED
AZZA Dynamo 850 850W ATX & EPS 12V 2.91 SLI Ready CrossFire Ready Power Supply
I HOPE THAT WORKS AND I ONLY SAY THAT BECAUSE I'M NOT SURE WHY THE FIRST TWO PSU(S) I TRIED DIDN'T UNLESS ITS BECAUSE THEY WERE AS GOOD OF A BRAND AS CORSAIR????
YOUR ORIGINAL THOUGHT WAS CORRECT YOU DONT NEED ANYMORE THAN 450 WATTS
