W w.aldemeri Prominent Nov 1, 2017 17 0 510 Apr 30, 2018 #1 Hi Guys I've just bought A Gt 1030 and I'm waiting for my power supply 300watt and It will take 14 day to deliver so Can I Put the gpu with 180 watt only ?
Solution A A asoroka Apr 30, 2018 I would suggest that the answer is no. You should check the Manufacturers recommendation, which is probably 300W. It is not worth mucking around with an overloaded power supply.
A asoroka Distinguished Apr 19, 2009 1,200 1 19,660 Apr 30, 2018 Solution #2 I would suggest that the answer is no. You should check the Manufacturers recommendation, which is probably 300W. It is not worth mucking around with an overloaded power supply. Upvote 0 Downvote Solution
