Power Supply amps and watts dont match up???
dthomp87
22
OK so im replacing a PSU on my SFF lenovo m82 computer that came with a 240watt psu. I added a low profile gtx 750ti and am getting power offs during gameplay. It should be enough power with 240watts to cover it but for the life of me i cannot figure out why it keeps shutting off and i have tried everything out it must be the psu at this point. possibly my psu is bad.
this mother board only has a 14 pin connector. it does no use 5v or 3.3v only 12v at 12amps(motherboard) and cpu 12v at 15amps, it does have 5.02vsb at 2.5amps and -12v at .2amps.
so this is a TFX form factor psu, so there are a few options but no many. most have lower amperage ratings on the 12v than mine does now even though they are rated at 300w (amps reserved for 3.3 and 5v)
so i came across this and already purchased the seasonic psu 300w
http://www.ebay.com/itm/251679406102?_trksid=p2059210.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT
it has 20amp at 3.3v, 5v 20amp, 12v1 at 18amps, 12v2 at 18amps -12v at .6amps +5vsb at 2amps.
im going to have to modify/splice to get the old connector on the new plug.
I wont need the 3.3 or 5v, so cut those wires off.
now im left with 2 12v lines with 18 amps each. which is 2 amps higher for the cpu and 2 amps higher for the motherboard.
should this work for me? i dont understand why 12v 18amp and 12v2 18amp should be 216 watts each thats over 400watts right there why is the psu rated at 300watt? i dont get the math on how that calculate this. could i really pull 18amps from each 12v line continously?
the old supply says 12v1 + 12vCPU not excede 230watts but when you do the math 12amp and 16 amp thats 336watts? how are they calculating this? my new psu says 252watts max between the two 12v outputs. so im only getting 22 watts more.....
thanks for reading im sure it got confusing at points.
"not to exceed 230 Watts" is the key.
I don't know this for sure but I suspect the separate lines are expected to have different consumption. Because each line is rated for 18 amps just means that it can draw 18 amps without damaging the components for that line. So if you max out one of the lines there will be less available on the other one and if you exceed the combined total you will overheat something.
For example on the 252 Watt PSU if you draw 18 amps on the 12v1 line that's 216 watts so there are only 36 watts (252-216) available for the 12vCPU line.
So while each line may be rated for 18 watts that doesn't mean you can draw the maximum from both at the same time.
so my setup
4gb ddr3 1600...............5W
8gb ddr3 1600...............10W?
SSDnow 240gb..............6W?
i5 3570.................121Wpeak
MSI GTX 750Ti (chip is rated 68watts peak, but MSI has afterburner technology which is overclocking the GPU which would take up even more wattage.. How much more would it take?)
id like to use the optical dvd bay and mechanical HD also but i have them unplugged for now to reduce power consumption... not sure of wattage at the moment.
I found that Seasonic also makes two other PSUs that have 300w at 12v and 348w for the 12v
i bit more expensive and i already have the other one in route, wish i would have known before i purchased i was only looking at the amps no the combined wattage rating.
