power supply and ups question
vlasis
26
i have an i7 6700k running at 4.3 ,32gb ddr4 ,2 ssd 500gb, 3 sata hdisks and a gigabyte gtx 1080 (not ti ).i want to change my power supply cause its old and an overkill ,but i am not sure about the watts.Also i might pick another gtx 1080 for sli,not sure yet.So, my question is ,first , how many watts it should be with sli in mind (apc calculator suggests 750), and second ,i need a ups too for the pc and a 24 inch screen cause i am having problems with the power in my block and i need something to protect me.Dont care for more than a 2 minute battery just for a proper shutdown,what i am interested is protection against any surge.i am having trouble understanding the proper watts /va for the ups,so any help would be really welcome. budget is kinda and issue so cant go for those 400 dollars ups
700W PSUs are not that common. It's easier to get a 750W PSU.
The UPS, that I recommended, has a pure sine wave wave form that is usually needed by current modern PSUs that use APFC (i.e. Active Power Factor Correction) so that the UPS will correctly switch over to battery backup mode when there is a power interruption event.
A...
A non-sine wave (a.k.a. stepped sine wave or something similar) UPS may fail to correctly switch over to battery backup mode, when there is a power interruption event, usually due to an incompatibility between the PSU's APFC circuit and the non-sine wave output of the UPS when the UPS is operating in battery backup mode.
thnx alot for your info man,really helpfull. one last thing, the ups ,its noise ,how is it if you know,loud or quiet?
I do use the CyberPower CP1500PFCLCD UPS. It doesn't make any noise when it's not in battery backup mode.
During a power interruption event there is a beep alarm that will sound. The alarm can be disabled from the UPS' LCD control panel if you don't want to hear any alarms. I don't even hear any humming from the UPS while it's operating in battery backup mode or at any other time.
i dont mind any sounds during its back up operation,i was asking during normal operation if it makes any noise,cause i usually let the pc on when i sleep ,but from what i understand its silent
On the rare occasions (maybe once a month), when the UPS performs its automatic self test to determine battery condition, you may hear some switch-over noise.
