Hello,
I received all my parts from this build I made : https://ca.pcpartpicker.com/list/HdCWJ8
After struggling to put the Cryorig H7 (that doesnt work because its am3, and no mouting adapter coming, I did request 2 times, no answer back...) so I am using the stock cpu cooler since it fits my mb, with a bit of presure. (uptd: I received an email from Cryorig, should receive in the next 10 days, ill just have to take out the cooler, clean cpu & add cryorig right ?)
Now I am not able to do my cable connection for the power supply, PSI-E connected, Perephical connected, but the MOLEX/IDE/SATA i dont know what cable to use, I looked up on internet, they only show supperior models that doesnt have the same connection has me... (I did check the tutorial of Seasonic, but its not the same as mine, so cable are a bit different) I will try to add pictures so people can see and maybe help me if possible, but I guess I can't add picture from my computer here, since its only url...
Thank you very much
Thank you very much
