Power supply cable
Mar 22, 2018
37
Was wondering if i needed a specific cable for my 750w power supply or any cable will work. In other words if i can use my old power supply cable on my new one.
New power supply: cooler master g750m
Old power supply:
xigmatek x-calibre series psu 500w
Different PSU models are all using different pinout. Many cables with same connectors can NOT work with another model as the wires are connected/arranged differently.
You may check with https://www.moddiy.com/ as they know pinout and compatibility for all PSU brands and models.
If you are talking about the cable that goes from the wall outlet to the PSU, then it should work. If you are talking about cables from the PSU to the rest of your components, then no.
