power supply calculator (pc part picker)
henkkrakers
Commendable
Mar 5, 2017
66
using pc part pickers power supply calculator. I don't understand one of the options.
Gpu overvoltage %. it ranges from 0-50%. what does 1% equal? in msi afterburner i can overvolt up to 100mv or 0.1v which is not a lot.
im just wondering how i turn 100mv into a percentage so i can determine what psu i need for my system using that calculator.
at 50% it says i need a 950w psu whereas at 0% it says i need a 650w psu. which is crazy varied.
why is 50% even an option i don't get it at all, anyone?
Outervisions SUX just like all calculators.
Post your build on PCpartspicker then post the perma link here I can tell you what you need.
For a 950 Watt PC even with overclocking your using some massively expensive hardware like SLI 1080ti's.
Your not going to get a 50% increase in power on a video card their no way and you could not keep it cool even if you could. (Can you see the smoke being released you would)
With a 50 % power increase on a video card and it jump 300 watts you would need to be using a 600 watt video card!!!!!!!!!!!!!!!!
i know right, i was thinking this is crazy too, so how do i determine the overvolt % lol.
here's my pc in partpicker. some of the parts weren't there so i picked something close to them. e.g. msi 1080 aero instead of 1070ti which is what i have.
it says 446 watt for those parts but that's not including overclocking
sorry here
https://pcpartpicker.com/list/ZVBFBP
Yes their adding 20 watts for each hard drive but your not going to be using all 3 at one time.
The thermal paste is not needed what comes with the cooler will work just as good.
750 watts will let you push everything to the limit.
Note: Wattages are estimates only. Actual power draw may differ from listed values.
Component Estimated Wattage
AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor 11W - 95W
Noctua - NH-D15 82.5 CFM CPU Cooler 5W - 10W
MSI - X370 GAMING PRO CARBON ATX AM4 Motherboard 17W - 70W
Crucial - Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory 11W - 11W
Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive 2W - 10W
Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive 4W - 20W
MSI - GeForce GTX 1080 8GB Video Card 45W - 180W
Noctua - NF-A14 PWM 82.5 CFM 140mm Fan 1W - 5W
NZXT - Aer F140 (Twin Pack) 103.4 CFM 140mm Fan 1W - 5W
Total: 105W - 446W
well i ordered a 750w psu now so that should be enough.
