C CrazyRookie Reputable Jan 13, 2016 12 0 4,510 Jan 13, 2016 #1 What motherboards(that are ddr3 1600) are compatible with the EVGA 500 W1 80+ ?
Karsten75 Judicious Oct 15, 2009 6,905 0 36,960 Jan 13, 2016 #2 compatible in what way? All motherboards require a 24-pin power connector and then optionally additional connectors on the mobo for the CPU. Upvote 0 Downvote
Dunlop0078 Titan Ambassador Feb 13, 2014 13,300 146 70,990 Jan 13, 2016 #3 Pretty much any modern consumer motherboard will work with that psu. Upvote 0 Downvote
D Derp88 Reputable Jan 15, 2015 108 0 4,690 Jan 13, 2016 #4 CrazyRookie : What motherboards(that are ddr3 1600) are compatible with the EVGA 500 W1 80+ ? I recommend the MSI Gaming 5 I have it and it works like a charm. http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770 BTW make sure to factor in other parts such as your GPU, and CPU power needs when getting your PSU Upvote 0 Downvote
C CrazyRookie Reputable Jan 13, 2016 12 0 4,510 Jan 13, 2016 #5 Can you give a list of names of what motherboards support two or more 4 pin ports and also all the wire that come with the power supply doesn't have to be connected ? Upvote 0 Downvote
C CrazyRookie Reputable Jan 13, 2016 12 0 4,510 Jan 13, 2016 #6 Derp88... See I had that motherboard but it didn't have the right ports or slots for the two fans that came with my vivo mid atx tower gaming case https://www.amazon.com/gp/aw/d/B011ALFZZM/ref=mp_s_a_1_1?qid=1452703533&sr=8-1&pi=SY200_QL40&keywords=vivo+mid+atx&dpPl=1&dpID=51hFqAG9HfL&ref=plSrch Upvote 0 Downvote
