O okstate98 Apr 24, 2018 1 0 10 Apr 24, 2018 #1 What power supply would be compatible with an HP Z230 SFF
Solution E E eric418 May 1, 2018 You will need a power adapter cable in order to use standard ATX power supply with HP Z230. HP Z230 Z220 PSU Main Power 24-Pin to 6-Pin Adapter Cable (30cm)
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,819 1,873 159,590 Apr 27, 2018 #2 The PSU for the workstation is proprietary , designed for that setup. Upvote -1 Downvote
E eric418 Distinguished Oct 5, 2011 57 1 18,665 May 1, 2018 Solution #3 You will need a power adapter cable in order to use standard ATX power supply with HP Z230. HP Z230 Z220 PSU Main Power 24-Pin to 6-Pin Adapter Cable (30cm) Upvote 0 Downvote Solution
