Hi everyone!
Building a PC and the strangest thing is happening. The 24-pin connector (it's split into 20+4) won't fit into the motherboard 24-pin slot.
The 20-part section fits just fine but the 4-pin part keeps sliding out. It has these little bulges on it that keep catching on the 20-pin part. Someone from the build a PC discord said the 4-part connector went on the bottom but it didn't even come close to fitting in the bottom (the patterns or whatever on the plugs didn't match).
Really at a loss here. Can the PC run with just the 20-pin connector installed? Should I grab a tweezer and see if I can pry off the little square bulges so it can fit in? Screenshots below...
