Power supply corsair cx750m vs cs750m
ImReadyD151
199
Looking for a good power supply that doesn't break the bank for my build. The cx750m is 80+ bronze and has been given great ratings by many people and the cs750m had 80+ gold and has been given good reviews by fewer people. Which would be the better one to go for, is it worth a few extra bucks to get the 80+ gold?
There's no reason to push for a gold or silver certification unless you PSU is 900-1000 watts or more .
I wouldn't spend extra money on that.
cx750m is a great choice
I was just looking on pcpartpicker, but newegg or amazon would be good. It would be nice if the power supply is plain black so it matches my build of black and blue.
What are planning to do with 750W first.
I don't consider the Corsair CX and CS series as good power supply. They are mediocre. They uses cheap caps inside and can fail easily under heat or stress, whichever comes first. Sure the reviews on retailers may sound nice but you should actually look at reviewers from power supply testers.
Prioritise quality over the 80 gold rating,modularity and looks. Your power supply is the only thing powering your pc components yet it has the ability to kill all of them.
I7, on a z97, sli gtx 770, watercooler, 5 fans. Overclocking
Then I'd just go with the m12ii 750w http://www.newegg.com/Product/Product.aspx?Item=N82E16817151107
It seems to be cheaper than the rest, is modular and is black like you want it to be :)
Well down the line I want to do dual sli with gtx 770's
Would it be worth it to get a rm or hx 750? Or could I get away with a cheaper one that will be really reliable. The reason I'm saying this is because I'm most likely ordering off of amazon prime cause the free 2 day shipping, and the total cost of some of those psu's listed above is around 115$ and the rm and cx aren't that much more expensive.
Well, you haven't listed your system hardware, [strike]so we don't have any idea if 750w is overkill or not enough 😛[/strike]
Edit: Ah I see you added that last part. Well the CX really aren't that good, and the CXM are just the modular version and preform the same. I would stick with any of the ones we have listed until you list your system and would NEVER cheap out on the PSU. It's a tough lesson if it ends up going bad on you.
@ jaraldo, he said this.
How does that rm 650 perform in your build?
Its doing ok for now. But i am not pushing it though. Once, the actual unit got really warm that the casing of the power supply could warm my hands for me in the winter during gaming. I estimate 30-40C. Personally i wished i had a better power supply than the RM 650. I should have waited for the XFX XTR 650 W but the price drop of the RM 650 got to me.
Hahaha I didn't mean to pick that as the solution, I'm on my kindle. I was going to say I was thinking about what you guys said about no being cheap with the psu, so maybe I should throw In a little more money for it. How do you think the hx750 would be. The reason I'm picking all these corsair products is because most of my build is corsair so I wanted them to match.
So what did you go with? How is your choice?
I went for the CX750M and have no regrets- reviews were good, efficiency is good, semi modular so I can cut down on cables, and really quiet - the fan doesn't pick up speed until it gets to over 55% of its rated output, and it can actually run at the 750W rating unlike many of the cheaper makes. (oc'ed my i5 4690K with Cooler Master Seidon 120V easily went to 4.8GHz so I'm sure more to come if I can be bothered/need it- currently turned back down a bit as don't need that speed just now but it's nice to know it's there!)
