When I installed my 600, I found that there was only the Sata cord and not the other small cord that is also supposed to connect to the hard drive... what should I do?
the two cables needed to connect to modern hard drives are the sata (data) cable and the sata (power) cable.
the only one the cx600 has anything to do with is the sata power cable. the data cable connects to the motherboard from the drive not the power supply.
