Power supply decision
mudassirmb1991
8
My PC specs are:
INtel i3 2120 3.3 ghz LGA 1155,
motherboard dh611,
GPU GIGABYTE GTX 760 2 GB (2.0 REV),
4 GB DDR3,
4 USB PORTS IN USE(AVG),
NO DVD WRITER,
NO FANS ( I SUPPLY POWER FROM AN EXCLUSIVE ADAPTOR)
Whic POWER SUPPLY should i get. I am going to use my pc for gaming purposes.
kindly suggest a specific brand name with model . thank you
You have to remember that that is going to have to power an i3, the mobo, the hard drive and a 760. It will need more then 430 watts to run reliably, especially considering gigabyte is usually generous when it comes to fans on a gpu.
Not really, i have a r9 280x and 4670k @ 4.6 and i don't take more than 400W. Most people with 770 / 680s and 3770k's i know don't take more than 350W, so he should be swinging around 300W, i think a 430W will be just fine.
