Question power supply destroyed my motherboard?
Mar 20, 2019
9
So I bought
mobo:-Msi b450 pro vdh
Ram:- Corsair vengance 8gb ddr4 3000 mhz
cpu:- Ryzen 5 2600
Things i already had (old)
some hard disk
zotac gtx 750 ti
corsair vs 450 power supply
Problem :-
After assembling all my parts my pc ran i was happy but as soon as i play any game my pc just restarts without showing any error msg i tried reinstalling windows and i tried again but then it crashed and did not start again.
So i took everything to some specialist he told me tht my mobo is faulty.
My question is which of my parts destroyed my mitherboard so i could replace that part before assembling again with replaced motherboard.
justin.m.beauvais
Respectable
Dec 15, 2017
1,124
43
2,290
240
It is possible that the motherboard just broke or was faulty to begin with. It happens more often than I like to think about. Really it could be any component causing it. The RAM or CPU can cause similar issues. So, RMA the mobo like was suggested, and if it fixes it then it fixes it.
Mar 20, 2019
9
i did replaced the motherboard and same thing happened, 2 motherboard cant get faulty by its own so i gave it again for repai/replacement l. eht could cause this to my motherboard ? should i get antec NE 550 psu?
Mar 20, 2019
9
Mar 20, 2019
9
both times it ran for few minutes then turned off and after that only fan runs no display so i gave it for replacement again.
All i wanna know is wht could be causing it my ram and cpu are new so it could be my psu?
Mar 20, 2019
9
[/QUOTE
I did got it replaced and same thing happene this is the second time i am getting it replaced from manufacture
Mar 20, 2019
9
temp of cpu were arround 56 and i played game for few mins it running well then pc restarted and then just crashed after few min. Can any thing other than psu cause harm to motherboard coz something did it 2 times in a row . Seasonic psu are very costly in india
Mar 20, 2019
9
my mobo is dead because of something my ram is new so i dont think thts the problem my pc was running fine but it was restarting then my mobo stop giving output only ffan spinning and stuff so i just wanna make sure that its my psu thts killing my mobi so i after i get it replaced i wont have any probs
