Greetings All,
Below is the system that I built last week. After the build I added several older drives that had info on them that I needed. Two were 1TB SATA drives and 2 older IDE 500GB drives. So in total I had 2 DVD, 5 hard drives and an edternal usb drive with files being transfered pluged in. The Rosewill RV2-700 power supply died after a day. Subsequently, I ordered and installed the CORSAIR CMPSU-850TX 850W power supply. I don't want to kill another psu so did I do something wrong with the original setup? It's running fine now but I only have 2 sata drives plus the dvd's hooked up. Is there something I should be doing to the older drives before installing them or was thhis just too much for the Rosewill.
Thanks All
GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Rosewill RV2-700 700W ATX12V v2.3 / EPS12V SLI Ready Power Supply
Seagate Barracuda 7200.11 ST31500341AS 1.5TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C9
AMD Phenom II X6 1055T Thuban 2.8GHz Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX
Microsoft Windows 7 Professional 64-bit
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply
Thanks All
