Recently purchased a used Dell Vostro 1510 laptop. Works great, battery holds charge for hours. If you start it up on the battery, no problem. If you start it up on the battery with the charger plugged in, no problem. But if you start it up on the battery and then plug in the charger, then the screen display goes wild. Tried 2 other known good chargers, same issue with all.
Any ideas of what to check?
