A Asyth May 26, 2019 6 1 15 May 26, 2019 #1 Hi I bought gigabyte z390 gaming x and it has 12 pin cpu 8+4 pins And i bought seasonic focus plus gold 650w that has only 1 cpu cable thas has 8 pin How can i plug the other 4 pin ? As pc part picker says there is no issues with the component that i picked !!
PC Tailor Illustrious Ambassador Jun 29, 2017 7,976 1,572 41,590 May 26, 2019 #2 You only really need the 12 pin if you are looking at extreme overclocking. It will still run fine with the 8 pin connected. Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,771 1,935 93,640 May 26, 2019 #3 The 750W to 1000W versions of the Focus Gold Plus come with a second CPU cable, the 550W & 650W do not. https://seasonic.com/focus-plus-gold Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 May 26, 2019 #4 Usually will run just fine with the 8 pin. Upvote 0 Downvote
A Asyth May 26, 2019 6 1 15 May 26, 2019 #5 PC Tailor said: You only really need the 12 pin if you are looking at extreme overclocking. It will still run fine with the 8 pin connected. Click to expand... Thank you for replying So thats mean my system will run at its full power with only 8 pin But the 4 additional pin for more stability in overclocking is that right ? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 May 26, 2019 #6 Most of the time the 8 pin will run it. If it's not stable upgrade the PSU. Upvote 0 Downvote
A Asyth May 26, 2019 6 1 15 May 26, 2019 #7 Dark Lord of Tech said: Usually will run just fine with the 8 pin. Click to expand... So the additional 4 pin is totally optional right ? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 May 26, 2019 #8 USUALLY yes. Upvote 0 Downvote
A Asyth May 26, 2019 6 1 15 May 26, 2019 #9 Dark Lord of Tech said: USUALLY yes. Click to expand... Thanks bro I will see how it goes Reactions: Banned by Net Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 May 26, 2019 #10 Sounds great , good luck. Upvote 0 Downvote
