Power Supply Fails Paperclip Test
samuelechu
16
I did the paper clip test on my PSU( OCZ ZX 850W). I plugged in the 24 pin cable, then I connected the two ends of the paperclip to the green and black wires. The PSU clicked once, fan did not turn on, then it clicked again. Is this a bad power supply?
Hello,
Yes. If the paperclip trick doens't work - most likely that PSU is gone.
Do you know what happened to that PSU? Was there a lightning strike? Brown out? Black out?
Anything weird happen before your PSU went toast?
Hello,
BTW i've done this before - and my GPU died and wouldn't turn on even with the paper clip trick - basically once I unplugged the 6pin power connectors from my GPU everything powered right up.
Maybe try unplugging your GPU and trying again.
Wow, I figured out what was wrong. I failed on interpreting the power switch symbols correctly. I thought that "o" meant on and the "l" meant off. *facepalm* :pfff: I plugged it all back together and it successfully booted:)
