Power Supply fan works with paperclip but does not turn on with Motherboard
mobu
I have recently bought a Solid Gear 850W ATX power supply from Amazon (model: SDGR-850E). Upon connecting the PSU to the motherboard for the first time, the power-up LED turned on and then off quickly. The PSU fan didn't move at all.
After I unplugged all the wires and cables and powered up the PSU again, nothing happens. No LEDS, nothing. I double-checked my wires and everything seems to be in the right order.
Paperclip Test: Passed
I followed a tutorial (]http://dodji.seketeli.com/downloads/shuttle-psu-paper-clip-test.pdf )to jump start a PSU by using a metal paperclip and the fan turned on alright.
PC Specifications
  • Motherboard: Gigabyte Z68X-UD3H-B3
    CPU: Intel Core i5 2500K @ 3.30GHz
    RAM: 8.00 GB Dual-Channel DDR3
    GPU: AMD Radeon HD 6750
Images
http://imgur.com/a/I4k8t#0
I have taken a series of images to help you guys help me better.
I am confused with which cable goes into the 12V ATX connector? I can't tell the difference between PCI and the ATX connector
Thanks a lot for your help!
Thanks. I just tried the cable and it was actually mentioned on the back of the box. I am now 99% sure that the PSU was DOA
I haven't yet. I just checked that the PSU ATX is v2.3 and my old PSU (that works with the mobo) is v2.2. Do you think this could be the issue?
