Power supply fans not spinning and no bios.
ikninja1
5
Hey guys, I've got some problems and I would really appreciate some help so that I can fix the issue in my hands.
So I just built my first PC but it doesn't work. The PSU fan doesn't spin but the motherboard gets power since there is a green light that lights up when I turn the PSU on. Also the lights on the front panel of the computer case works. The CPU fans and case fans don't turn on either even if I connect the fans directly to the PSU. I have tried two different PSUs and the fans in both don't turn on. I try to power the PC on from the front panel but nothing happens so I cannot see the bios.
I have some pictures here:
http://imgur.com/a/FATYK
Any suggestions? Thanks.
UPDATE: I have tried the jumper and it has had an effect. The PSU and case fans have started spinning. However, if I turn the PC off and then back on I have to redo the jumper process. Is there any way to fix this? Thanks.
Here are my PC specs:
EVGA 650 watt power supply
Asus A88XM-A Motherboard
Corsair Vengeance 8 GB (2 x 4 GB) DDR3
AMD A10 7850K Black Edition
By default, the jumper connects 2 and 3 pin. You said that your PC did turn on, did you set the jumper back after shutdown? If so, then set jumper to connect 1 and 2 pin and leave it there.
I thought about that too but he has tried 2 different PSUs with the same result.
Even then, atleast case fans should turn, especially when connected directly to the PSU.
Sorry for the late reply. I have tried the jumper and it has had an effect. The PSU and case fans have started spinning. However, if I turn the PC off and then back on I have to redo the jumper process. Is there any way to fix this? Thanks.
