Power supply for gtx 1060
toshibitsu
When/if you visit nVidia's website, it will display detailed specs on your video card(usually you have to click "specs - view full specs') & it will tell you at the bottom of the page the required power/connectors needed. Granted, if you have multiple hard drives, optical drives, etc... you're probably going to want to go above the recommended requirements.
Zerk2012
Ambassador
The watts they recomend means absolutely nothing. They have no clue what parts your using in the PC.
The video card has a TDP of about 120 watts that is all they should tell you.
