dstark
7
I'm getting a GTX 550 TI and I'm not sure what wattage I need from the power supply. I currently have a 250 W I believe.
It's a stock Dell Inspiron 560 PC, Pentium (R) Dual-Core CPU - E5700 @3.00 - GHz - 3.00 GHz, 6 GB RAM.
The recommended power rating isn't listed on newegg for the card like some of the others.
Any help is appreciated.
For a system using a single GeForce GTX 550 Ti graphics card NVIDIA specifies a minimum of a 400 Watt or greater power supply that has a combined +12 Volt continuous current rating of 24 Amps or greater and that has at least one 6-pin PCI Express supplementary power connector.
dstark
7
What card would you recommend then? I basically don't have a video card and i run diablo 3 now but its choppy. Don't need anything crazy, and important shorter on cash than expected.
Thanks ko! If i have 250 and need another 400 i may as well get get a 700w.
