Power Supply for GTX 680 and Case
Finkss
38
Hello,
I'm building a new PC and is only missing the Power Supply and Case.
VGA: Zotac GeForce GTX680 AMP 2GB
Processor: Intel Core i7-3770K
MotherBoard: ASUS TUF Series SABERTOOTH Z77
RAM: Corsair Vengeance Blue 16 GB
HD: Western Digital Caviar Black 1 TB SATA III
What power supply would you recommend for this PC? I really do not understand about power supply.
And the case? One with good ventilation ... In the future, I was thinking of putting a Corsair Hydro Series H100.
Thanks
Can you find any CoolerMaster HAF cases or possibly a Antec 1200? One case I personally like is the Cougar Evolution.
HAF series- http://www.coolermaster-usa.com/category.php?category_by=1&category_id=1698&category_name=HAF
HAF X- http://www.coolermaster-usa.com/category.php?category_by=1&category_id=1746&category_name=HAF%20X
Antec 1200- http://www.antec.com/product.php?id=693&fid=4
Cougar Evolution- http://www.cougar-world.com/us/products/pc_case/evolution.html
There are a few different models (black as above, black and red and white and black).
I wanted a PSU with high quality. I can spend 150 bucks.
About the case, I wanted a case with good ventilation and has space for a good cooler, I was thinking in H100. But this cooler show you it feels good.
I liked this case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139010&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=18muvhhqmb7x4
Is it good?
I am from another country and did not find that in any case the corsair store.
What do you think about this caseThermaltake ATX Black Armor + VH6000BWS or Thermaltake ATX Spedo Full Tower VI90001W2Z
I found a shop here in my country. The single version of HAF X is the NVidia. But it's so ugly. But it's so ugly. I wanted this corsair 500R but do not have here.
If you don't like it then don't get it. It's not worth it to spend that much on a case you don't like. None of the cases listed are really bad just post the ones you like the most that they have. Neither of those Thermaltake towers are bad I just don't personally like the looks although if you do those could be a good choice.
My friend recommended me a computer store. And I found that more cases and found the corsair.
Which has better quality HAF XM pr Carbide Series 500R?
That's corsair has no problem cooling?
If it is good, equal or similar to HAF XM I'd take it.
