Power supply for GTX 780 ti WINDFORCE?
Gregz777
127
The title is as simple as it comes.
I need to know of a adequately compatible power supply that will work perfectly with the 780 ti WINDFORCE edition, please note the WINDFORCE, as it uses TWO 8-pin slots.
Here's the exact name that was displayed on the website of the very card that I bought, in case you want it for technical reference:
GV-N78TOC-3GD - 3GB Gigabyte GTX 780Ti Windforce 3X, PCIe 3.0 (x16), 7000MHz GDDR5, GPU 1020MHz, Boost 1085MHz, Cores 2880, DP/DVI/HDMI.
I need a power supply that will have two 8 pin cables, or the sockets to have these cables plugged into it, if you see what I mean. I know nothing of what is best and why.
Please also note that the 780 ti WINDFORCE requires at least 600 watts of power, so I am going with a 700w power supply. No more, no less, unless you deem it absolutely necessary.
My relevent specs are as follows:
CPU: Intel core i7 2600 @ 3.40Ghz
RAM: 8gb
Motherboard: Foxcon
H61MXL/H61MXL-K
That's all. I'm sure this is a lot simpler than it has been made out to be in my head, but I really do need some help.
As for PSU: Corsair RM750 is $100 after $20 rebate on Newegg right now
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139055&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
650 is a bit too low, and 750 is a bit too high. I'm looking for exactly 700 watt power supply suggestions. Also note that I've edited a bit of information in my post as I was wrong about the pin slots. The graphics card needs ONE 6 pin slot and ONE 8 pin slot from what I've seen. I need a power supply that has these cables, or has the ability to have these cables plugged into it.
Anyone out there still following me? D:
I've made a mistake. My graphics card DOES take TWO 8 pins. I suppose the power supplies you've linked will be compatible with this? Can I plug two 8 pins into it so I can plug the other end's of the cables into the graphics card?
All of the PSUs posted so far will plug into a 780 ti. They all have the correct plugs. They are listed as 6+2 pin plugs.
Ah, I had no idea 6+2 was used to resemble 8 pin connectors. Because of the separate 2 pins, will this be a problem that it's separated from the other six? Or do I just pair them all together into a total of 8 and plug it into the power supply and card?
