Power Supply for gtx 960
Vikrant1
34
Hello Guys, I am Planning to buy Gtx 960 and i require a PSU. Please Suggest me a good PSU of 450W in India, My Spec. is
CPU- Intel Core i5-4690
Mobo- Biostar H87-MLV3
RAM-Transcend 4GB
No I am not going to add another graphics card...As you are Saying I should buy 500W PSU Please tell me the Brands or Specific PSU in india And i will Go for it..Considering Price 3k to 3.5K
My budget is from 3 to 3.5k In India..Considering Corsair Or Cooler master..Heard Good About Them.. Sorry Mistakenly Voted -1..
Considering These
1-http://www.flipkart.com/corsair-vs450-450-watt-psu/p/itmdbfa3kaffmum3?pid=PSUDBF9ZBHSJVGJ8&al=JJK890cd%2FBXNKh2J3jeIxsldugMWZuE7JTWSsYnGIuU9u5KT655%2Bgip8xw%2FCxq9%2B%2BS%2BmlSoIFws%3D&ref=L%3A5385774678882078086&srno=b_1
2-http://www.flipkart.com/cooler-master-thunder-450w-450-watts-psu/p/itmdbm7fpuzpszvf?pid=PSUDBM7EDGK2XYFZ&al=JJK890cd%2FBWJWZEvtqoFwcldugMWZuE7JTWSsYnGIuUCrZd5%2Ff%2BtuFrjFdUrGGBCL%2BVHFZHHxe0%3D&ref=L%3A5274541778938514002&srno=b_2
I'd still go for the EVGA one, just for the 5 year warranty and overall quality you get from EVGA. Order their PSU and you'll be surprised. I just got mine and the packaging was amazing, PSU was solid and worked fine.
Ya, i read a lot good reviews about evga and their support but Only Problem is EVGA is not having a market in india..So I have Good options From cooler master and Corsair and you can suggest more..except EVGA.
Oh...ok, in that case go for the cooler master one, although they are both just fine PSUs.
Neither of those units are good. The Corsair VS series is regarded as the worst PSUs that corsair sells and the CM thunder is just as bad if not worse.
If I get the Seasonic will go for it..and if not then I will go for the one hexit mentioned..
Or should I consider these
1.http://www.flipkart.com/corsair-vs650-650-watt-psu/p/itmdg36xznfnesye?pid=PSUDG347RBUYNCFK&affid=kanujcand
2.http://www.amazon.in/gp/product/B0092ML0OC/ref=as_li_tl?ie=UTF8&camp=3626&creative=24822&creativeASIN=B0092ML0OC&linkCode=as2&tag=candytech-21
3.http://www.amazon.in/gp/product/B00ADKORP6/ref=as_li_tl?ie=UTF8&camp=3626&creative=24822&creativeASIN=B00ADKORP6&linkCode=as2&tag=candytech-21#productDetails
