power supply for mainboard ms-7050 ver:2.0 socket 939?
okppko
351
ms-7050 ver:2.0 socket 939 amd athlon64 x2 3800
Was built into a HP dx5150 computer.
Can an atx power supply 300w power this mainboard?
Thanks.
Thank you. I have overseen something. Maybe you can answer me. I have used this 20 pins power supply: Euer power model cwt-300atx-a300wmax. At the top right on the data sticker on the power supply it says atx 2.01. I used it on a mainboard, that says the power connector must be atxpwr1, it has 20pins.
I have counted the pins on ms - 7050 ver 2.0 socket 939, and the number is 24pins. I have read https://en.wikipedia.org/wiki/ATX_power_supply#Interchanging_PSUs I cannot determine whether I can use the power supply on the ms 7050 mainboard? And if I can, what do I do with the 4 more pins on the ms 7050? I cannot test it, because I will not obtain the ms 7050 until I know, it can be connected to the power supply.
That's why i highlighted this one. 😀
Brand
FSP Group
Model
ATX300-PA
Spec
Type
ATX 12V (v2.2)
Maximum Power
300W
Fans
PFC
No
Main Connector
20+4Pin
+12V Rails
PCI-Express Connector
No
SATA Power Connector
SLI
No
Modular
No
Power Good Signal
100-500ms
Hold-up Time
12.0mS minimum at 115V/60Hz or 230V/50Hz (Full Load)
Efficiency
> 70%
Over Voltage Protection
+3.3V (4.6V max.), +5V (6.5V max.), 12V1 (15.5V max.), 12V2 (15.5V max.)
Overload Protection
Yes
Input Voltage
110 - 127/220 - 240V
Input Frequency Range
50/60 Hz
Input Current
7A @ 115V, 4A @ 230V
Output
+3.3V@20A, +5V@20A, +12V1@16A, +12V2@16A, -12V@0.8A, +5VSB@2A
MTBF
100K hours at 25°C
Approvals
UL, CSA, TUV, NEMKO, CB & FCC
Features
Connectors
1 x Main connector (20+4 pin)
1 x 12V (P4)
4 x peripheral
1 x SATA
1 x Floppy
Features
Remote ON/OFF Control:
The power supply shall accept a logic open collector level which will disable / enable all output voltage (excluding +5V standby).
Over-current protection: +3.3V (66.0A max.), +5V (50.0A max.), 12V1 (27.0A max.), 12V2 (27.0A max.)
Temperature range: operating 0°C~50°C, storage -20°C~65°C
Humidity: 90~95% RH
Dielectric strength: primary to Frame Ground 1800 VAC for 1 second, primary to secondary 1800 VAC for 1 second
