Power Supply for My graphics Card
yobro03
8
I have just bought a new rig, and have this graphics card which requires 2 six PCI-e connectors.
http://www.neoseeker.com/Articles/Hardware/Reviews/winfastgtx260/
I bought this power supply to run it from ebuyer
http://www.ebuyer.com/product/124927/show_product_reviews
Which i thought would do the job. My problem is the power supply only has 3 molex connectors and no six pin PCI-e connectors (my fault i admit) so i have to use all the molex's for this. But when i turn on the comp the fan on the graphics card doesn't spin and the monitor doesn't turn on.
Any thoughts?
yer i can send it back if needs be just a shame didnt realise power supplies came with so few molex connectors these days.
Its rated higher than it likely should be, it isnt one of the better brands. Corsair is a good brand and is sufficient instead of overkill for the card. The fact that that power supply is cheap but rated significantly higher does not indicate quality parts. Remember if a PSU goes it can nuke your whole system.
Yer i think i'll go with the OCZ not that much more expensive should have gone for it in the begining, cheers guys
