aces19 :
guymargalit1000 :
Yes it is 800W PSU, cool
BTW, does it count as a decent GPU ( I also saw the MSI version of the 980 ti, is it better?) I want to buy a high-end card that will be good for the years to come..
I've heard that in six months or so there is going to be a new generation or something of GPU's, is it worth waiting and not upgrading now?
I am in the exact same situation as you, and I chose to wait. The new "Pascal" GPUs, as they are called, are supposed to be very good, and even if they aren't, I'm sure they will soon release a "Ti" version of one of their best "Pascal" cards, for example a "1080 ti" One thing I am not sure of is the price, but we will have to wait and see.
As for your PSU, 800w will last you literally forever.
And as for your graphics card, this is the 980 ti with the best performance out there: https://pcpartpicker.com/part/gigabyte-video-card-gvn98txtreme6gd
I have a little problem with the GIGABYTE GPU, because it's 2 cm more in length from what I currently have and I am afraid it won't fit in my case..
I added a picture of my case where you can see that my GPU almost touches the metal thing there where the HDD sits.. This is right before I cleaned it a few weeks ago! it looks great now
and yeah, I live in the desert so a lot of dust
Anyway, what I want is basically a high-end GPU that will serve me for a few years on the highest settings possible in games (currently playing in 1080p, not planning to move to a higher resolution..)
If the gtx 980 ti will suffice, I think I will take it.
