Power supply for new system
alladinsane
53
Hey,
I am putting together a new system and was wondering if the power supply I am planning on using is ok. I did not want to spend too much on a psu, but I also wanted something that was not a piece of crap and that would ruin my system and eat up a ton of electricity. The system is as follows:
ABIT KN8 Ultra
AMD Athlon 64 3200+ Venice
OCZ Gold Series 1GB DDR 400
6800 GS
Western Digital Caviar SE WD1600JS 160GB
NEC ND-3540A
Creative Sound Blaster Live! 24bit
FSP AX450-PN ATX12V 450W: http://www.newegg.com/Product/Product.asp?Item=N82E16817104954
Thanx
Any other drives? CDRW or DVDRW? That FSP should be good with that system. Try it and if it doesn't work then you can replace. I'm not sure how much OC you can pull out of it, but it will run the system at stock speeds.
Thanx for replies. I am actually wondering if this drive will be power efficient and quality. I will eventually be adding a 7800 of some type and a dual core and more RAM, but no otehr drives. Also, I will not be o/cing
thanx
