G Guest Guest Mar 1, 2015 #1 I have cooler master 500W PSU and i3 4150 processor along with H81M-S1 mobo with pcie 2.0 slot . will be gtx 750ti compatible with these ?
Wolfshadw Titan Moderator Aug 3, 2006 28,523 1,699 133,290 Mar 1, 2015 Solution #2 Yes. It's 100% compatible. -Wolf sends Upvote 0 Downvote Solution
Archaic59 Polypheme Jan 6, 2015 10,037 647 69,240 Mar 1, 2015 #3 750 Ti only requires 300 watt PSU. Edit: 400 watts according to this chart: http://www.realhardtechx.com/index_archivos/Page362.htm Upvote 0 Downvote
Sig2525 Reputable Sep 19, 2014 1,464 0 5,660 Mar 1, 2015 #4 the required watts posted in the nvidia site for a gtx 750 ti is 450 watts Upvote 0 Downvote
G Guest Guest Mar 1, 2015 #5 have a question will this config of mine support r7 265 dual x card too ? Upvote 0 Downvote
Wolfshadw Titan Moderator Aug 3, 2006 28,523 1,699 133,290 Mar 1, 2015 #6 Specs state it requires a 500 watt PSU for the entire system, so it should handle it ok. I might look at a 550-650watt PSU though. -Wolf sends Upvote 0 Downvote
