Power supply for s2460?
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.tyan (More info?)
Anybody have a specific power supply they can name me for an s2460 Tiger MP?
I've had trouble with my board not POSTing, and am down to that as a last
resort
Won't POST with a single or double MP 1800+ CPU and a single stick 512mb RAM
that is verified in a s2466 and known to be functional. CPUs were guaranteed
not DOA, but used. T-Bird 950 verifiable working won't POST, either.
Keyboard is known to be functional. Banshee 16mb AGP and GeForce2 MX400 also
known to be in good working condition. I get no beep codes whatsoever from
BIOS, so assume it's PSU, because the VGA has a beep code, I believe.
Thanks,
J
PC Power & Cooling makes very high quality power supplies. Their 510
ATX should work just fine with the S2460 MP mobo.
http://www.pcpowercooling.com/products/power_supplies/highperformance_
d/turbocools/index_hp_atx.htm
I am using a 475 ATX (older model) with a Tyan Tiger MP S2460 with 4
SCSI drives, CRDOM, CDRW, digital tape, etc. No problems.
Good luck! HTH
On Thu, 29 Apr 2004 01:57:59 UTC, "J McK" <oderus2010@yahoo.com>
> resort
> Thanks,
> J
Tom Brown
thombrown at san dot rr dot com
Member SCOUG, V.O.I.C.E. & SDAA
running eComStation GA + FP 3
eCS system uptime is 0 days 00:42 hours
Sweet. Right now, I have a 450 ATX, no-name, putting out 35A on the 5v, and
I thought it should work, but no luck. I have seen the board function on a
power supply over at my friend's house, when I bought it, but he was
re-using his supply for the s2466 he bought (Long story involving the wrong
cpus and me snatching up this board for a STEAL)
"Tom Brown" <thombrown@san.nospam.rr.com> wrote in message
news:1dg3dd6yrPYX-pn2-BdvxXzCdghw3@localhost...
> Good luck! HTH
MP?
last
> > resort
RAM
guaranteed
also
from
> > Thanks,
> > J
> Tom Brown
The S2460 is VERY picky about PSUs (and memory - has to be registered DDR).
I've had the best luck with an Enhance ENS-0246 PSU after my Enermax PSU had
the dreaded ATX connector meltdown problem. If you're not sure what I'm
referring to, have a search through the www.2cpu.com forum threads for it.
I'm not sure if the S2466 NEEDS registered DDR so memory that works in that
may NOT be suitable for the S2460 - best to check on Tyans approved memory
list for the S2460. I know genuine Samsung works fine on mine.
Finally, allow a few seconds from switch on until you give up and cut the
power. It takes about 30 seconds from power on for mine to show the post
screen because its checking my ECC Registered memory - one of the quirks
with this board.
Paul
"J McK" <oderus2010@yahoo.com> wrote in message
news:HiZjc.1359$Gq1.425@fe2.columbus.rr.com...
MP?
> resort
RAM
guaranteed
also
> Thanks,
> J
MP?
> resort
RAM
guaranteed
also
I exchanged a 400w antec with a 550w enermax. The system froze with the 400w
after a succesfull post.
Try running your cpu's at 200mhz fsb (jumpers):if the rig runs, it's the
psu....
Paul.
"Miloman" <me@privacy.net> wrote in message
news:c6rkm0$fb4b5$1@ID-216380.news.uni-berlin.de...
> MP?
last
> > resort
> RAM
> guaranteed
> also
from
400w
> psu....
> Paul.
On that 200mhz FSB jumper note ... the motherboard markings and the manual
indicate that two of the four jumpers move from 1-2 to 2-3 setting, while of
the other two, only ONE is supposed to move from 2-3 to 1-2, and the other
is supposed to stay at 2-3. Is this a typo, or is it correct that three of
the jumpers move, while the fourth stays the same? If you've got the same
board, you can look and see, maybe it's a misprint, but boy tha sounds weird
that one of the pairs is supposed to be mixed while the other pair both
change.
Do these jumpers affect memory speed as well? As in, will PC2100 run at 200
mhz as if it were PC1600, instead of the 266 mhz it is capable of? Not that
it matters much, if it gets my system happy and shows me that I just need a
new PSU.
Thanks,
Jon
news:3iskc.43150$Vp5.20479@fe2.columbus.rr.com...
Tiger
> > MP?
> last
> > > resort
512mb
> > RAM
> > guaranteed
MX400
> > also
> from
> 400w
> > psu....
> > Paul.
of
weird
> change.
You better check here (mind the revision-part):
http://www.tyan.com/support/html/f_tg_mp.html
As i remeber there was an issue with a misprint in the manual, so it's
probably wise to get the latest version of the manual suiting your revision.
I'm sitting in the garden rightnow, so can't check my rig..... maybe
tomorrow.
200
that
a
> new PSU.
I assume it also affects the memory speed, but i'm not sure here. It might
also depend on the SPD-info.
Let us know the outcome!
Paul.
I can echo that the 2460 is VERY picky about PSUs.
I have a 2460 that the PS gave up on. So I went to the local computer store
and bought a brand-new 550 w PS with tons of room. The board wouldn't post.
Traded it in on a different PSU that was 450 w and barely met the 5 volt
requirements. Board posted with no problems. The PS that wouldn't post the
2460 works just fine on my 2466.
Moral of that story was not to give up on the 2460 because you tried a
single (or maybe even 2 or 3) new PSUs. I never did get to the bottom of
why a perfectly good PSU for a 2466 will not post a 2460.
MP?
> resort
RAM
guaranteed
also
> Thanks,
> J
> MP?
last
> > resort
> RAM
> guaranteed
> also
from
> > Thanks,
> > J
Well, I tried the board with the PSU that it was originally tested with.
Known to be a good PSU, since I saw it POST with my own nine eyes before I
bought it. It didn't POST. RMA, here I come.
"J McK" <jmckenna2@neo.rr.com> wrote in message
news:qf8mc.65285$Vp5.3736@fe2.columbus.rr.com...
of
Tiger
> > MP?
> last
> > > resort
512mb
> > RAM
> > guaranteed
MX400
> > also
> from
> > > Thanks,
> > > J
How do you know the PSU's capabilities didn't deteriorate with age since the
first test? Just because the PSU still runs other boards, doesn't mean it'll
still have enough get up & go to handle a Tyan S2460. PSUs that are getting
on a bit sometimes deteriorate due to the effects of heat on their workings
and can no longer output as much as they used to. What PSU make/model/power
rating is it?
Paul
i've been using antec truepower 550watt psu - it died almost exactly 1 year
old but comes with a 3yr warranty so i got a free replacement within a
couple of days courier collecting defunct model
this powers a radeon 9700pro, audigy, 3ware raid card, lan, 3 ata100 hdds,
dvdrom & burner, 3 ram sticks 1280mb, 4 case fans & 4cpu fans (silverados)
and 2 mp1600+ cpus
the absolute best psus are supposed to be from pcpower & cooling - usa only
though
dr ratt
