Power Supply for Sapphire HD 7850 2GB OC Edition
uchihaobito
21
Hi
I need help in selecting a psu for my system. minimum how many Watts of power supply do i need to run my system with graphic card overclocking. Here r my Specs:
i7 3770K
Gigabyte Z77X-UD3H
2 TB hdd
250 Gb hdd
8 GB Ram
Samsung Optical Drive
Currently using a Cooler Master 400W Psu.
Thanks.
Your ok with the psu youve got! Unless you have a half decent graphics card which i didnt see listed in your specs mate. If your just using the onboard graphics on your cpu then your fine.
Flipkart.com this site does provide a lot options but cannot choose which one will be right. can u go thru d site and recommend a psu. my budget is Rs 3500. i dont how 2 copy d link sorry. this is d last time i promise. Thanks
This one will 100% be fine for you friend http://www.flipkart.com/cooler-master-thunder-500w-500-watts-psu/p/itmdbm7fefnpygyn?pid=PSUDBM7EDH7YSFTZ&ref=9f498f73-84e6-4eb9-8ca0-987656533453&srno=m_1_1&otracker=from-search&query=psu.
Use this program to check how much power your system is using friend. http://extreme.outervision.com/psucalculator.jsp . Youll know for definate what wattage your system is using.
