Hi Guys,
So first ill give you a bit of a background on my situation. Over the past month my computer has randomly been crashing to a black screen then restarting. During those time ill be able to get back into the desktop other times it will do it at the password screen. I have reinstalled windows and gpu drivers thinking it would be them, however the problem is still persisting. I have swapped out my SLI 570's for a single 6750HD for the mean time and no crashing has occured. However, my cards had been working fine before this month. After checking crashing through blue screen viewer, it appears to be a 116 error, which is GPU timing i think. BUt i have go my mate to test both cards for 1 week each and no issues of crashing what so ever.
So im thinking maybe its my PSU, however i have never tested one. I read through overclockers.net that you can test your psu through speedfan (no idea of how accurate those results are) to see it rail voltage and so have done so and the results are as follows:
At Idle
3Vsb: 3.41V
Vbat: 3.33V
Vcore: 0.83V
+12V: 6.45V
AVcc: 3.30V
3Vcc: 3.30V
VIN1: 1.01V
VIN2: 2.04V
VIN3: 0.92V
GPU Vdcc 1.00V
I have no idea what these mean, but the +12V is low isnt it? I tried to do a load test using interburn test and OCSCANNER however the +12V only went up to 6.55V and no higher. That was also after 1 hour of testing.
Any help with this would be much appreciated as im unsure what else the problem maybe. Im hoping its the PSU as ill just buy a new one and wait oput my GPUs till the GTX 980 TI's are released.. but if the PSU is fine then i guess its the GPUs
Thanks in Advance!
TheGrid
At Idle
3Vsb: 3.41V
Vbat: 3.33V
Vcore: 0.83V
+12V: 6.45V
AVcc: 3.30V
3Vcc: 3.30V
VIN1: 1.01V
VIN2: 2.04V
VIN3: 0.92V
GPU Vdcc 1.00V
Thanks in Advance!
TheGrid
