My 500w power supply has a cut wire in the 24th pin, the black one in the 4/24 pins (that seperated one with 4 pins) like the wire itself wasnt cut, it was more like pulled out and you can see the copper wire, is this fixable? Or fine?
You can remove the pin itself from the 24 pin plug and fix it, if its further up the wire and you need to cut too much excess away to get to that point, just cover it with a piece of electrical tape.
