power supply have enough Power??
DavidUSSR
281
Hi i want to buy new power supply for my system..
The power supply that i want to buy is Antec 650W EDGE 80+ GOLD
And my system is
Intel Core I3 6100 3.7Ghz
HyperX Fury 8GB(2X4GB)
EVGA GTX960 SSC ACX 2.0+ 4GB GDDR5
5 Corsair Air Series AF120 Quiet Edition (Red Led) fans
Does this power supply have enough wattage??
650w is WAY more than you need and is plenty of power for the system. with that said, there are probably cheaper psu's out there that would work for you.
we can offer some choices if you wish to buy online or you can stick with that high quality antec psu if you wish.
@KieranPCGamer, as already noted, the antec edge is made by seasonic for antec. so your comment is not exactly a very good one considering this information. seasonic makes a ton of psu's for a number of companies including antec, evga, xfx and others.
Thanks for the answers but i think id go with the antec one because the seasonic are too expensive in my country and the one are in normal prices they are not fully modular so i think i made my descision
it's a solid choice so no worries there. i know prices and model availability changes from country to country. you got lucky and found a high quality unit at a decent price. in some countries only junk psu's are affordable with quality ones being way too expensive for the average user.
the antec edge is made by seasonic so u still got one:)
