Not quite sure what to say. Do you live in a country where the power at the wall is 230Volts, or did you mean to state it was a 230WATT psu? Also, look at the label on the side of the PSU for brand, model and power - especially the +12v power in amps, not watts.
According to AMD/Radeon the 7870 Ghz edition (non-OC) requires a minimum 500 watt psu for the system power, with a minimum of 23amps on the +12v rail: It is NOT the total wattage that is most important, but the total current available on that 12v rail
Most quality built/namebrand psu's with 500-600 watts will have more then enough power for your system: Quality units are Seasonic, XFX, Antec, EVGA V series, Corsair (not RM units, they are not perfected yet).
Here are two links that list PSU's by quality levels. AVOID Tier 4 and 5 units.
http://www.eggxpert.com/forums/thread/323050.aspx
http://www.tomshardware.com/answers/id-1804779/power-supply-unit-tier-list.html
Repost with the requested psu info and your budget (in your local currency) and we can offer up some suggestions.
UPDATE, 12/27/13 6:05p.m. PST. Matt, check your private messages. This will make more sense after you read what I sent you.
Here are a couple suggestions for power supplies:
CORSAIR CX series CX500 500W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
CORSAIR TX Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Compatible with Core i7 Power Supply & New 4th Gen CPU Certified Haswell Ready
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
this is a nice unit built by super Flower; excellent quality.
Rosewill CAPSTONE-550-M 550W Continuous @ 50°C, Intel Haswell Ready, 80 PLUS GOLD, ATX12V v2.31 & EPS12V v2.92, SLI/CrossFire Ready, Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182262
Any of those have more then enough power for your new card and system. If those don't agree with your budget, then all I can tell you is make certain you buy a reputable unit: Something made by Seasonic, Corsair, XFX, Antec, Enermax. Do more research if need be, expecially on Tom's and at jonnyguru.com and hardocp.com etc. to find out who really manufactures the psu you become interested in and what the professional review have to say about it. The three I listed are all really good and well built units.
Looking forward to your reply.
