Power supply help
JBoi72
34
hello everyone ^_^
http://www.walmart.com/ip/iBUYPOWER-Gamer-Power-WA557APU-Desktop-PC-with-AMD-A10-6800K-Richland-Processor-8GB-Memory-1TB-Hard-Drive-and-Windows-8.1-Monitor-Not-Included/26464578
i bought this computer then i noticed that my cpu temp is like 78-85 without really doing anything.. even on google chrome. my friend says that its because my cpu and gpu are together since its integrated and that if i got a graphics card that my comp wont run laggy when playing league of legends and it would also cool down my computer because it wont be using the integrated graphics + cpu or something..
anyways i was looking at this graphics card to buy since its in my budget range
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127703
but it says if u look it needs a 500 watt power supply and my comp only came with a 300 if u look at both links. so i was wondering whats a power supply i can get to run everything thanks!
Your A10 should not be going much higher than 70. I dont think its possible for it to run at 85 because it would have been throttling like crazy if it reached 80. What program are you using to monitor the temps? If you can stretch your budget, the best gpu to get would be a GTX 750 Ti without a 6 pin connector. If you can't, get the regular GTX 750. Make sure that the cards do not have a 6 pin connector since 300w power supplies dont have them. You can run a 750/ti without a 6 pin connector on a 300w psu even if the requirements say it needs more than 300w.
a generic psu of 300w would more likely have 240w on the 12v rail and 240/12=20A which is the recommendation of 750ti
i wouldnt trust my hardware on a low quality psu working maxed out all the time. it may work but better have a decent psu with a bit of a headroom and for o/c
chris if i get the 750 ti that you linked which 1 of those power supplys should i buy that you linked? and can you link me to a cheap/good cpu cooler pls 😀 ? can u link all 3 at once so i can just book mark them!
https://www.youtube.com/watch?v=VuP6I0mOb1s
http://pcpartpicker.com/parts/partlist/ 212 evo can fit in your NZXT Source 210 since it is in the compatability list 😉
Depends on what CPU you are using, but you don't disable it it's something you control through BIOS but you shouldn't have to if you don't want too.
as i mentiomed erlier, since your not planning an overclock you may lower your cpu temps by reapplaying the thermal paste to avoid the cpu cooler upgrade! also after upgrading to a dedicated gpu it wont operate as an APU anymore. with the intergrated gpu disabled the temps of the cpu may decrease under load!
