power supply help
The only difference would be the plug, everything else would be fine. If you buy the one from Amazon USA, you could try to contact the sellers to see if they can send you a UK plug, or you can just pick up a standard computer power supply plug, as the SeaSonic one you listed uses the standard 3-pin power plug in the back.
