P poth Reputable Oct 1, 2014 8 0 4,510 Oct 1, 2014 #1 How do I know what type of power supply my deal vostro 200 supports? I want to upgrade, but will it fit my case? I have the normal tower, not the slim
S SchuIIe Reputable Jun 29, 2014 56 0 4,660 Oct 1, 2014 #2 just go and google your tower. then look what kind of psu's it supports. usually atx standard Upvote 0 Downvote
P poth Reputable Oct 1, 2014 8 0 4,510 Oct 1, 2014 #3 well My pc tower cant seem to find it, its almost like noone uses it. Upvote 0 Downvote
maestro0428 Splendid Apr 3, 2009 2,866 40 22,090 Oct 1, 2014 #4 You should be able to use any normal sized ATX psu. I recommend Seasonic. Upvote 0 Downvote
P poth Reputable Oct 1, 2014 8 0 4,510 Oct 1, 2014 #5 maestro0428 : You should be able to use any normal sized ATX psu. I recommend Seasonic. well next question real quick, on the back of the pc, the psu is covered by the metal plates, what does this mean for new psu that is a differnt shape? Upvote 0 Downvote
