power supply help
fyfeqt
18
hi there on my power supply it says max wattage 123w max wattage output 123w
but under that it say's (total output continuous shall not exceed 500w) does it mean that it is a 500w power supply or is it a 123w power supply ?
fsp group inc. modol no : fsp500-60HHN
ok so i can put up to 400w in my pc with that psu ? or still 123w
You can draw up to 411 Watts continuous total from the combined +3.3V, +5v and +12V rails.
intel i5-4440 KFA GT 740 1GB gigabyte GA-B85-HD3 rev 2.1 two WD HDD both 1TB OS windows 8.1 64-bit crucial ram at 1600mhz not 100% sure the modol numbers on my cpu, gpu, ram ,motherboard, i have also got 3 fans in my system 2 LED ones but only 1 LED fan spin's but the lights on it are on and the other 2 spin
Motherboard: gigabyte GA-B85-HD3 rev 2.1 ... 40 W
CPU: Intel i5-4440 .......................................... 68.3 W
Memory: Crucial RAM at 1600mhz ..................... 6 W
Graphics Card: KFA2 GT 740 1GB .................... 64 W
HDD: two WD HDD both 1TB ........................... 20 W
Cooling Fans: 3 fans (2 with LED lighting) ...... 15 W
Total: ............................................................ 213.3 W
So what's your problem?
im thinking of upgradeing my graphics card but i wanted to know my psu specs befor i did so im getting i can use near to 500w in my pc?
GTX750TI-OC-2GD5
150w
The ASUS GTX 750 Ti OC 2 GB [GTX750TI-OC-2GD5] draws a maximum of 74 Watts when running Furmark Stability Testing. During gaming its peak power draw is 65 Watts.
That FSP power supply unit should have no problem powering your system with that graphics card.
that's great but on http://www.amazon.co.uk/Nvidia-GeForce-Graphics-GDDR5-PCI-Express/dp/B00ICUGOP0/ref=sr_1_1?ie=UTF8&qid=1417044628&sr=8-1&keywords=gtx+750ti amazons website it say's that its 150w
They are absolutely wrong.
It may have faulty capacitors or whatever though.
Why? Because you said so?
