AdGo :
http://pcpartpicker.com/p/7PhnRB
Here it says 353 W but when I calculated on cooler master power calculator it said 422W
It looks like the Cooler Master calculator, since it is only allowing you to select generic items is providing worst case power requirements (ie. taking into consideration overclocking and/or padding the numbers to account for 3rd party cards.)
This can be a good thing.
With PC Part Picker that seems to show the average power draw of the components selected without OC but with brand specific values.
What I typically suggest when using PCPP is to take the value they provide add another 15%, then round up to the next half century. (353 * 1.15 = 406 --> 450W) This would be the absolute minimum PSU wattage...
